NX7 - Lightweight models
Hi all,
We (the company I work for) are currently using NX4 and we produce a lot of large assemblies. I've installed NX7 on one machine as I was on the understanding that we may benefit from some of the JT features.
Am I correct in thinking I should be able to add a view and detail it using the JT reference set? I've added a view but I can't seem to turn off hidden edges. It might be that I'm missing something :(
Any help VERY MUCH appreciated.
Mark Noyce
Senior Design Engineer/CAD co-ordinator
RE: NX7 - Lightweight models
Best regards,
Michäël.
NX4.0.4.2 MP10 / TCE 9.1.3.8_build_0711 / NX6.0.2.8 / NX7.0.0.9
Belgium
I've turned hidden lines to invisible but I can still see them :(
Am I right that I should be able to do this with the JT? Also, is using the Lightweight (FACET) reference set the same as using JT?
Thank you
Mark Noyce
Or use the Visible layers in view function, CTRL+SHIFT+V and use the reset to global button for the sheet and all the views.
Best regards,
Michäël.
Belgium
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
John R. Baker, P.E.
Industry Sector
Cypress, CA
For some reason I was under the impression that this could be done in NX7.
Oh well that explains the issues I'm having, am I right that lightweight is the same thing as JT?
Thank you!
Mark Noyce
John R. Baker, P.E.
Industry Sector
Cypress, CA
