How much air density benefit from CAI vs warm air under hood
I've seen several questions recently about whether a restrictive CAI would be better than an open filter sucking in warm air under the hood. Depending on the restrictions, of course, It seems to me that the small % inc in density of cold air vs warm will not be as beneficial as an open filter assy sucking freely at the warm under hood air. This could be a much larger % change so it could be more beneficial. What do you think?
RE: How much air density benefit from CAI vs warm air under hood
Rod
Rod
worst case F(ilter)AP at WOT is say 97 kPA absolute, even on the worst intake I have ever seen, short of the one that squashed flat, and say it warms up to 40 on the way in to the filter (which would be very bad indeed) so density is 1.2*(273/(273+40))*97/101
In practice you'd have to be nuts to lose 3 kPA in the intake pipe itself, but you could be unlucky with the position of the orifice. Try and mount it where all the bugs get squashed.
Cheers
Greg Locock
Unfortunately math isn't my strong subject. I haven't seen the exact equations you used but have seen similar. I did a similar thing but with density figures I got from a reference book:
Temp=30C, (86F); density of dry air at 30C=1.1649 gm/liter
Temp=40C, (104F); density of dry air at 40C=1.1277 gm/liter
Decrease in density due to temp rise = (1.1649-1.1277)/1.1649 * 100 = 3.19%
I don't know if the engine power is exactly linear with air density, but this at least shows a 3% drop in density (oxygen available) with air only 10°C warmer. So, 3% of a possible 200hp=6hp gain with 10° cooler air.
Is this what you mean?
So, using 3% per 10 degrees, that would be a 12% loss, but the pressuure is possibly 3% higher, for a net reduction in air density of 9% for the underbonnet system.
To a reasonable approximation the power of a street engine is proportional to the air mass flow rate, which is the air density times the speed times the volumetric efficiency times the swept volume /2.
So if you don't change any of the others then then power will be proportional to the air density.
Cheers
Greg Locock
I think you and Greg are being a bit conservative on the under hood temps. The only test(early 70's) I ever did on this subject using a mechanical pyrometer (primarily used for tire temps) indicated a lot higher temps. on a Lotus Elan. (we had changed to 45mm Webers and the 40mm airbox would not fit) Very limited space in a very small car---ran a duct through inner fender panel to special K&N filter housing. Not perfect, but a bit better. Still had to deal with under fender heat.(I used the same method on my Lotus Cortina except I went to the headlight bucket) I don't recall the exact horsepower numbers, but It was about 3 hp at the rear wheels. If I am remembering the hp figures correctly thats about 3% increase. Well worth the effort! (The testing was on a portable chassis dyno with large squirrel cage blowers to simulate road speed so the hp numbers were for comparison purposes only.)
AND---as I reread this it is entirely possible that a small change in jetting may have been needed. That means the test(?) is not exactly 'scientific method'!
Rod
The intake side of our engine is generally around the 80 mark, but the exhaust side would be any silly number you want, obviously. We used to burst hydromounts due to heat soak from the downpipe - glycol everywhere.
Cheers
Greg Locock
I have an '89 Pontiac Trans Am, 5.0L, tuned port injection. If I remove the air conditioning I can easily run an intake tube down to the underside of the engine compartment. Even a very flexible plastic tube has to be squashed to fit between all the hoses and wires in the way now.
Evelrod mentioned going to the headlight bucket. That is the closest access to outside air that I have. My intake snorkel is about 4" diameter but the hole in the wall behind the retracting headlight is only about 2" diam. I can see a narrow space between the wall with this hole and another wall in front of it (headlight mechanism maybe). My initial thoughts were that trying to suck air through these narrow gaps would be too restrictive, that's why I opted for the hot under-hood air.
To use the holes behind the headlight I'd have to find a way to construct a slanted, cone-shaped device that would connect to my snorkel on one end and butt up to the wall with the holes at the other end. So far I haven't gotten any good ideas. I'm not the type to tear things apart if I don't have to. In fact, I'll settle for hot air if I can't get the cold easily enough.
During my experiments with modified air filtering mechanisms, I saw how the car would act if I pushed it too hard for the amount of air it could inhale. This is the only way I know of to tell me if it's able to breath freely enough. If it turns out that it can't breath freely enough through the holes behind the headlight, then I'm back to the choice of restricted cold air or lots of hot air.
Time to wander through the hardware stores again with a head full of ideas looking for stuff I can use. Thanks to everyone for helping me approach the problem from the right direction.
http://www.geocities.com/sciguyjim/index.html
and click where it says "My Car" at bottom left. (There are a bunch of other photos there too you might get a kick out of.) Enjoy.
you might prefer an insulated/non conductive material, I suspect- but a long tube with no fins is a lousy heat exchanger anyway, right?
(how do you past pictures, again?)
Jay Maechtlen
