Sinusoidal phase locked loop IC: Anyone know of one
Hi, I can't seem to find any IC phase locked loop that outputs a sinusoid. All the ones I've found have square wave and triangle wave outputs, and a digital phase comparator. I realize I can just do a triangle to sine conversion but there must be an IC out there that does it all.
Thanks.
Thanks.
RE: Sinusoidal phase locked loop IC: Anyone know of one
Benta.
To your problem: my solution would be to multiply your input frequency with a PLL multiplier, perhaps ~1000 times.
Use the counter in the multiplier to drive a ROM containing a sine lookup table. D/A convert, filtering out the high-frequency "fuzz" is easy.
Cheers,
Benta.
This is just a part of my circuit so I don't want the PLL to take up half a breadboard.
The closest to single chip are uP design applications for inverter control from Microchip where the sine is in the software.
Fairly effective down to below 1Hz.
The square wave output is used in a conventional PLL, and the fairly good sine wave output drives the external load.
A two chip solution is probably the best you can hope for.
Another option is the XR2206 to generate the sine output, and use the XR2211 to provide PLL functionality.
They have both been around a long time, but are still currently manufactured.
