Geothermal loops under building
I had an architect pose a question for which I could not give an immediate answer. A 30,000 sf slab on grade building is being constructed. Aside from the structural concerns about disturbing the soil which may degrade the bearing capacity, could most or all of the gshp horizontal loops be buried under the building? The idea would be to trench down 6 to 8', etc. I've done vertical systems and horizontal systems outside of the building, but never under it. The floor of the building will be insulated with 6" eps insulation.
RE: Geothermal loops under building
I would not put a horizontal loop under a parking lot though, too much solar radiation in the summer could hinder heat rejection.
