punching capacity of unreinforced slab
does anyone know how to prove punching of a column on a unreinforced or 'lightly' RC slab. ground supported?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: punching capacity of unreinforced slab
DaveAtkins
This will be laid out in any concrete design textbook.
In doing a new spread footing design I usually select the depth of the footing based on punching or wide beam shear. When doing the initial design, I only use the plain concrete to calculate the shear capacity.
http
But....what you would use for you distance and concrete shear strength is up to you or your code.
DaveAtkins
The BS8110 method is more closely dependant on the area of steel and uses a beam shear type flexural shear strength calculation.
But both require the tension face reinforcement.
Personally, I have never designed unreinforced sections for punching shear, never having believed in the concept but some codes do allow it. Make sure it cannot fall anywhere!
thread592-213921: Design of Slabs on Grade for Warehouses
http://
