"Rules of thumb" for column roof layouts
Hi All
I am designing a 36m tank where the client requires a column supported roof. I am doing the preliminary layout for the roof members and wondered whether there were any industry rules of thumb for layouts that lead to efficient designs, ie:
Max spacing between circumferential collector beams to keep radial rafter sizes practical. It seems to me this number should be kept to around 4-5m. Ie for 36m tank if I use 3 x equi-spaced circ collectors can limit span of radial rafters to 4.5m.
Max spacing of column centres to keep collector beam sizes practical. Seems 6-8m would be practical here?
Layout of columns; Obviously the max span of collector beams will set this distance in the outer most "ring" Are there any rules of thumb for how to lay out the inner ring columns in relation to this ??
Also: Is it typical to keep the roof angles low and allow the radial rafters to be welded directly to the circ collector beams or are cleats normally used for this attachment??
Appreciate any feedback from those who have done a few of these.
Cheers
Cheers
RE: "Rules of thumb" for column roof layouts
On the welding rafters to beams- it is done both ways. Probably some form of chair is more common.
