Calculation of overpressure
Hi all,
Could you tell me how I can calculate the overpressure in 2" pipe API 5L X52 which cause blown up of the pipe by 50%.
RE: Calculation of overpressure
If so, don't calculate .... run.
Surely it's too late to run!!!
"We have a leadership style that is too directive and doesn't listen sufficiently well. The top of the organisation doesn't listen sufficiently to what the bottom is saying." Tony Hayward CEO BP
http://www.youtube.com/watch?v=hpiIWMWWVco
"Being GREEN isn't easy." Kermit
http://virtualpipeline.spaces.liv
Apply Newton's second law to velocity of the metal fragments flying past your head. If your head is still there, relate the initial velocity and particle mass to a driving force, loaded area and thus a pressure.
Yeah baby.
thanks for the answers. I am doing accident analysis this why I need to calculate the overpressure of the explosion.
I thought I can calculate the pressure using the proprieties of the material but I don't know what is the relationship.
P = S * 2*t / D
P = Pressure, psig
t = wall thickness of pipe, inches
D = Pipe outside diameter, inches
S = ultimate strength of the pipe material, psi
or
S = yield strength, if it only expanded and didn't actually burst
Any place that the pipe is still pipe-like (i.e., round and intact), was subject to forces equal to the yield point, and that is what that equation shows you. So I guess you could solve it for the pressure using the pre-yield diameter to get the pressure when it probably started to yield (the published number is the minimum specified yield stress, actual yield point is always higher than that, it is not possible to generalize how much higher or to go back to a piece of pipe that has yielded and test it since the act of yielding changes the mechanical properties).
That pressure will be the highest that the pipe saw since the tensile strength is less than the yield strength and the yield point is a maximum. If the pipe stretched to 150% or 500% it doesn't matter since if you redo the equation above for the larger pipe diameter you'll get a lower pressure (i.e., the diameter tends to change a larger percent than the wall thickness change). The new diameter is just a measure of the pipe's elasticity, not a measure of the pressure it was subjected to.
I'm thinking that the hoop stress calcualtion will give you the overpressure, but it will be very conservative and I would present it as an "at least" number.
David
The pipe didn't ruptured but blow up.
Could you tell me the equation to calculate the internal pressure.
Our lab has measured the hardness and found HV 253, is there any relation with internal pressure.
Thanks for help
Blowing up 50% and not rupturing is pretty remarkable. How gradual (or not) was the pressure build up?
rmw
I would use the pressure when the pipe started to yield as the probable max pressure and assume that everything that happened after that was at a lower pressure.
David
David
