limit of overhead condenser
How do you calculate the hydraulic limit on an overhead condenser. the hx spec sheet specifies fluid tube side in lb/hr and lists the specific gravity.
It then states the max flow is given. If we were to change the composition how would you get the new max rate.
Is the limit a function of volume or a function of mass??
