How to model simple level shifter circuit
I am building a level shifter circuit for digital signals. It is part of a digital circuit test system. Input signal comes in by coax cable to a pair of 0.1" header pins using z-trace connector. Output signal is also uses coax cable connected to a pair of 0.1" header pins with z-trace connector. My level shifter falling-to-falling delay must match rising-to-rising delay. I am using an On Semi MC100EPT25 to convert my 3.2-4.0v input to a 5-8.3v output. The datasheet indicates very strong pulldown and weak pullup. If I connect this directly to my output headers, will I get slow rising edge? Should I use a pair of inverters between the level shifter and the output headers? There is no SPICE model for this part. Is there any way to simulate how this output might look?
RE: How to model simple level shifter circuit
Doesn't that depend on your REQUIREMENTS?
"There is no SPICE model for this part. Is there any way to simulate how this output might look? "
The datasheet tells you everything you need to know to do a simulation
TTFN
Coaxial cable is normally 50 ohms Zo. 5 volts peak into 50-ohm cable is 100 mA peak. 8.3 volts is worse at about 166 mA.
So **if the coaxial cable is long enough** (compared to frequency) to act as a 50-ohm transmission line, then this IC might have a very difficult time driving it.
TTFN
Table 5. TTL OUTPUT DC CHARACTERISTICS VCC = 3.3 V; VEE = −5.5 V to −3.0 V; GND = 0.0 V; TA = −40°C to 85°C
Symbol Characteristic Condition Min Typ Max Unit
VOH Output HIGH Voltage IOH = −3.0 mA 2.2 V
VOL Output LOW Voltage IOL = 24 mA 0.5 V
For pulldown it can sink 24mA with only 0.5V shift of Vol off the rail. For pullup, sourcing just 3mA causes Voh to shift down 1.1V off the rail. 24mA TTL is a nice marketing ploy by On Semi but it does NOT reflect the actual capability of the part.
I found a document that says that a typical undrilled hollow via has capacitance ~1pF and inductance ~2nH. Maybe a through holw header pin would be about 10x these values?
What length? Long enough to act as a transmission line at the bandwidths being discussed?
For test systems, ICs exist for exactly this function. Search for ATE Pin Driver.
Benta.
Apologes in advance if I'm making bad assumptions.
The point is that if you can design a driver circuit that can drive a 50-ohm cable with a sharp pulse (high bandwidth), then the stray capacitance of the pins is probably not something that would be a show-stopper. The proper approach is to do the best you can to match the impedance of the traces and pins to match the 50-ohm cable. That way these items just become part of the transmission line.
You've still not explicitly mention the bandwidth that you're operating at. But it would have to be fairly low to get to the point where you could ignore transmission line theory when driving a 1.5-meter long coax. Especially when you're so concerned about controlling pulse transition times.
I am leaning toward adding a buffer and a 30ohm termination resistor after my level shifter. This should square up my edges and provide some protection from reflections. I don't want to fall on my sword to match impedences since the bandwidth of this system is somewhat low, but if I have the buffer there it is no problem to add a resistor.
