Residual Stresses in a metal body
Hello, I'm new to Abaqus and could really use some help. I am trying to use Abaqus CAE (6.9) to analyze residual stresses introduced by internal pressure in a simple model (I'm starting out using a perfectly plastic assumption to start and will slowly make it more complicated as I learn more). I believe I have the material mechanical properties correct (using Elastic Modulus, Plastic strain and density), but I am unsure what kind of steps I need to use to create and view the residual stresses. If theres anything else you think I missed, please let me know. I appreciate any help you can give. Thanks!
Ron
RE: Residual Stresses in a metal body
Apply the loads in one step, remove them in the next. View the results.
Tata
Tried it again this morning and got it to work (not really sure what I did differently this time though). thanks for the reply anyway.
Ron
