Point Table in NX6
Point Table in NX6
Point Table in NX6
Is there a way to automatically create a table in drafting mode that would contain all the points x,y coordinates included in a view?
Also, is it possible to auto baloon those points let's say using their name and the first column in the points table would be those names?
RE: Point Table in NX6
Only if you or someone else writes you a custom application.  Depending on which version of NX that you're using, we do offer something similar for creating a 'Hole Chart' on a drawing, but it only know about holes in you model, not just points.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Hi John,
using NX6.. can you give us a program to generate this table of points in drafting mode?
Appreciate your help..
Thanks a lot Hudson. Would it be possible to publish the code so I can make some modifications to it and convert it to a journal?
Thanks in advance.
Sorry I don't have a copy of the source that I can hand out, but take a look in the grip library which I believe may still exist somewhere on the PLMS BB and I suspect you may find some similar examples.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
