A simple span extensible cable under a point load
Pals
anyone knows an iterative formula to determine final vertical displacement of an initially taut but extensible cable(properties E,A,L) under a point load P at midspan?
or recommend a good book with such basic problems?
any input will be highly appreciated.
respects
ijr
respects
ijr
RE: A simple span extensible cable under a point load
Try this:-
http:
desertfox
If you want to hand roll a solution then an energy approach may be less annoying than a force triangle.
Cheers
Greg Locock
I would like to personally thank you for the publication. I wish the engineering industry published more of this kind
respects
ijr
any book you know that does energy methods on cables. I have a book but it just doesnt handle basic issues and doesnt answer simple questions
respects
ijr
btw, i saw afterwards (i quickly read your response and shot back) that someone had given him a star for the link (it looks like a really good reference). if it was you, mea culpa.
energy methods ... would relate the internal strain energy to the work done (by the weight of the cable and the applied load).
I didnt know of a the littlepurplestar. thanks
any info you have on this please supply. I am going to use ropes in some temporary works
respects
ijr
but I solved one simple span, assuming vertical sag, and increasing it in steps, each time solving for extensions, strains and forces using PL/EA and simple statics , until force x vertical sag = PL/4, and it worked ouf fine.
The final sag matches results from finite element nonlinear analysis
unless you object on this, I will go ahead and do things using this basic approach.
respects
ijr
Your welcome.
desertfox
www.SlideRuleEra.net![[idea] idea](https://www.tipmaster.com/images/idea.gif)
www.VacuumTubeEra.net
