Best design for taking hot asphalt samples
Good night:
The way that I am taking hot asphalt samples in the refinery has a big impact on the environment because when the sampler is being displaced, all the asphat goes into the ground, and will accumulate until it goes to the ground, later going to sea. What are the best practices for the sampling of such products and avoid this type of contamination
