ICPR model setup question
I am a relatively new ICPR user, and had 2 questions regrading model setup for a project. The project only has one basin, and there are 2 subareas.
In existing conditions, the site is undeveloped (i.e., no pipes, channels, ponds, etc.). Therefore, I have 2 nodes (one for each subarea) - and I am trying to determine how to model the peak flow for the basin without any links. Basically, I am trying to figure out how to set up the exsiting conditions model in ICPR to produce the same results as I would get using the ADDHYD command for the subareas in TR-20 (i.e., how to get a peak flow for the composite hydrograph of the basin without routing the individual subarea peak flows).
My other question (for the proposed conditions model) is similar in nature. I have a pond in one subarea (Subarea 1),and a small storm drain system in Subarea 2. I have also added a boundary condition.
The Tt in the storm drain system (which is quite small) has already been incorporated into the TR-55 Tc calcs. Again, I am trying to determine how to ADDHYD the routed Subarea 1 hydrograph with the unrouted Subarea 2 hydrograph.
Any help would be greatly appreciated.
RE: ICPR model setup question
Proposed conditions-
IF you are modeling the storm drain system in ICPR (entering each inlet, pipe etc.), do not include it in the Tc or Tt.
As far as building the network, from what you describe, a minimum would be:
1. a downstream boundary NODE with the unrouted BASIN attached..
2. a NODE representing your pond.
3. a BASIN attached to the pond (or muliple inlet NODES with subBASINs and pipe LINKS to the pond)
4. LINK(s) from the pond NODE to the boudnary NODE representing the pond outlet(s).
