Embed linked JPG
Embed linked JPG
How do I permanently embed a JPG image into my drawing do it goes with the drawing without having to include the seperate JPG file ? I have someone here who is constantly moving folders around the network drive, and we can't get him to stop. He's the boss' current favorite... You know how that goes !
Thanks !
Thanks !
RE: Embed linked JPG
You may need to convert the .jpg to a .bmp first.
____________________
Civil 3D 2008, Terramodel
Civil Development Group, LLC
Los Angeles Civil Engineering specializing in Hillside Grading
http://www.civildevelopmentgroup.com
http://www.civildevelopmentgroup.com/blog
The second method we used was to just place the pictures in the "dwg" folder where we keep the .dwg file. Whenever AutoCAD loads a .dwg file it will, by default, look in the same folder as the .dwg file if it can't find the picture located in the original location.
Thanks for the suggestions ! I'm just returning to ACAD as my primary tool for this next project. We've been using it as a companion, and in some ways primary driver, to another 3D application, and they worked well together. Its just that when you couple some of the still existing rough edges with ACAD (albeit a fine, well matured product) with the kludges of other less mature systems, you try to look for solutions that tend to minimize workarounds if possible.
Thanks again for the input !
