How to scale curves?
The old transform dialog has been on the move, and seems to be completely gone now (NX 7.0.1.7).
How do I scale curves?
NX 7.0.1.7 MoldWizard
RE: How to scale curves?
Transform - Scale should (non associatively) scale a curve.
Mike
QED! But inelegant.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
I design plastic bottles. When I used "CAD system X", I could build say an 8 oz. bottle. If I wanted a 16 oz. bottle that had to look like a family to the 8 oz. I would figure out a scale factor, taking into account things that will change between the two bottles, like say weight and finish size. I could then copy the 8 oz. part and apply the scale factor. The system would multiply every dimension by the scale factor. The resulting part would be very close in volume and I just had to do a little tweaking to get it right. Every feature could be modified as if I had built the geometry myself from scratch.
I can't do that now. I have to go through each feature individually and modify every dimension. That's what I mean by not being associative.
Mike
None of the cheats posted would work here. Searched command finder for "x-form"... looks like a surface only tool. Searched transform and found what I was looking for, turns out I put the #@(*!# thing on my toolbar last time I spent a half hour looking for it but havnet used it since and forgot what the hieroglyphic meant. Looks like it isnt in the menus anywhere.... thats helpful.
Mike
