CMU Wall Embed Plates
I'm reviewing calculations for perimeter cmu wall embed plates connecting a continuous angle to a roof deck. The embed plates are designed to transfer lateral forces to the walls. Each plate has one row of two headed stud anchors. The equations used are the following:
Ap = Pix((Lbolt)^2) + 2(sqrt(2)xLbolt)xSpacing
Tension:
B(A Masonry) = .5xApx(sqrt(f'm))
B (A Stud) = .2xAbxfy
Shear:
B (V Masonry) = 350^(1/4)x(sqrt(f'mxAb))
B (V Stud) = .12Avxfy
Does anyone recognize these equations and if so, can you please tell me what reference I should be using to check them?
Tension:
Shear:
RE: CMU Wall Embed Plates
