Solidworks 2010: Mating a fairing to a sweep
I am attempting to mate a fairing part to a sweep (my cable). The path of the sweep is a spline to simulate the free movement of the cable. I am having a difficult time getting the two to mate properly. Any suggestions? Thanks for the help.
RE: Solidworks 2010: Mating a fairing to a sweep
"...a difficult time..." doesn't really give us much to go on.  Have you tried adding sketch geometry or reference geometry to your parts?
Dan
www.eltronresearch.com
Dan's Blog
Can you not put a point on the guide curve of your swept part and then mate the planes of your other part to that point?
Jeff Mowry
www.industrialdesignhaus.com
A people governed by fear cannot value freedom.
To clarify:
I think it is best to open the attached image to see what I am trying to accomplish then read the body of this post.
I am modeling fairings that are attached to a cable. I have created the cable using a sweep that will follow a equation driven line. There are over 800 fairings so I am trying to use patterns to model this. The fairings are linked together like a chain. What is the best way to accomplish this rather that individually mating all the links together?    I had several thoughts: 1) Create a small section of 6 links fully mated together and pattering or repeatedly inserting that sub-assembly  2) Insert the path sketch into the fairing part file and use a curve driven pattern.  The end goal is to show several configurations of different link lengths and fairing spacing. Is there a better way to do this? Is there a SW tool that will help me do this? Thank you.
