highly distorted elements
Hello !!
I need some advice concerning a problem of distorted elements that happens after a plastic/rubber contact (using conta174 and targe170). The geometry deals with 2 plates. The element used is solid187 with non linear activation. I refined the mesh at the contact interface.
I applied a non excessive load (100N) on the top plate and blocked the 4 lines of the bottom plate.
When I launch the calculation I have a problem that indicates "one or more elements have become highly distorted". If you need further information to answer my question, you can ask me whatever you need.
If someone has any idea to help me...
Thank you.
Thank you.
RE: highly distorted elements
I get that warning on a pretty routine basis and I've never encountered problems. Just look at a number of cross-sections and make sure that the deflection and stresses are flowing in a manner consistent with the loads and restraints. There may be a few elements which end up a little odd, but FEA is not a magical box. It has limitations and you will get hotspots where you know for a fact that the answer is wrong. But that doesn't make the rest of it incorrect.
Engineering is not the science behind building. It is the science behind not building.
Indeed this "error message" was predictable as the structure deformation is so important... Sorry I'm a beginner :)
Now I have another question that deals with a second contact that occurs after the load increases and I don't know how to face this problem. Maybe I can rise the load until the contact occurs and impose the contact conditions... Or maybe an ansys command exists but I didn't find it...
If someone has an idea...
Thanks !!
Cheers
Greg Locock
I would really appreciate some advice concerning my problem. You can find attach a picture describing the matter of my preoccupation.
Thanks a lot.
I'm not familiar with your particular FEA program, but have seen this in others.
Good advice.
But I succeeded in solving my initial problem, I posted my second message because of the contact between the 2 bottom layers(cf picture)that occurs after the elastomer deformation.
I don't know what condition to take into account between the 2 surfaces that will be in contact during the load increment...
I'm working with Ansys Mechanical LS-Dyna
Thanks for all your previous answers.
