Specific Ground Motion Hazard Analysis in West Virginia
Hi All,
I'm trying to perform a Site Specific Ground Motion Hazard Analysis in West Virginia. I have done these previously in California where there are many discrete faults but that isn't the case in West Virginia.Is this analysis typically performed in this part of the country to attempt to reduce the seismic design category as is the case in California?
My problem is: what fault would I use for the deterministic part of the analysis? The discrete faults are 100's of km's away where attenuation relationships are not considered valid. The only one valid for the Eastern US I have access to is Toro (97). Is this a commonly used relationship in this part of the country? Most of the probabilistic seismicity based on the 2008 USGS deaggregation is from gridded sources.
Is it customary to use the gridded source with the R and M as shown in the 2008 USGS deaggregation as a discrete fault in the deterministic analysis? The other smaller problem is that I'm using the 2008 USGS Deaggregation for the probaibilistic part of the analysis. It will only provide values for Vs-30 of Site Class A and B/C, whereas I need it for Site Class C. I'm assuming I can just apply Fa and Fv coefficients to get to a Site Class C?Thanks, any suggestions are appreciated.
One approach I am considering is to use the Deterministic Lower Limit as the Deterministic MCE as specified in ASCE 7-05. However, this may be unconservative and I'm not sure how the reviewers would perceive it.
RE: Specific Ground Motion Hazard Analysis in West Virginia
Boore, D.M. and G.M. Atkinson (1987), "Stochastic prediction of ground motion and spectral response parameters at hard-rock sites in eastern North America," BSSA #77, pp. 440-467.
Toro, G.R. and R.K. McGuire (1987), "An investigation into earthqauke ground motion characteristics in eastern North America, BSSA, #77, pp.468-489.
Nuttli, O.W. (1981), "Similarities and differences between western and eastern United States earthquakes, and their consequences for earthquake engineering," Proc. Conference on Earthquakes and Earthquake Engineering: The Eastern US, Knoxville TN, v.1., 24-51.
I'd hunt for other papers by Gail Atkinson also. I think she's at a university in eastern Canada, and may still be working on eastern North America attenuation and such. A paper by McGuire probably has too much higher math for me to be able to read in less than a month.
I have a feeling that the local building department almost anywhere in the east is going to say "Huh?" when you ask them about any sort of higher-level seismic study (except near Charleston SC).
DRG
Toro is one of the predominant references here. There are some others and some fairly new sets of AEs. Toro also has newer AEs than '97.
