BSPP thread and NPT
BSPP thread and NPT
BSPP thread and NPT
Hello guys,
I am buying a compressor from the UK and bringing it down to the US for some work.
The compressor comes with several thermowells for the temperature switches, but I have to substitute them with Temp Transmitters. I have to buy the RTD's for the transmitters.
The thread on the thermowell is 1/2" BSPP, where it bolts into the compressor housing. Is this compatible with 1/2" NPT? the pressures we are talking about is around 500psi on the thermowell.
RE: BSPP thread and NPT
Not compatible at all.
BSPP is not tapered, NPT is -- in addition to slight differences in thread forms and pitch.
You can make an adapter perhaps, or find a 1/2" NPT to 1/2" BSPP adapter -- just might need to make your probe a bit longer to get to the bottom of the thermowell.
OR, find a 1/2" BSPP sensor...
Let's see if anyone else knows a good and quick solution.
Good on ya,
Goober Dave
Not compatible at all (nor is DIN compatible with ANSI, just in case you get to that one next).
There are groups which sell BSP/NPT adapters, which is probably your best bet.  Then you instruments stay standard and your odd ball fittings can just stay on the compressor.
What kind of RTD's are you thinking of using?  I'd use a 1/4" o.d. RTD, and slide it thru a compression fitting 1/4" o.d. x 1/2" BSPP.  Have to drill thru the fitting first to create a clear bore at 1/4" + some wiggle room...
The thread angle & number of threads per inch are different.
Why not buy the correct thermowells with the RTDs?
