Sweep cut along 3d sketch (complex path)
How can i sweep cut along this 3d sketch (in light blue) all i could get it to do was the first segment..
[IMG]http://i 58.photobu cket.com/a lbums/g254 /asv4k8/sw eepcut.jpg[/IMG]
Then i need to mirror it over also.. any pro's on here know a way to do this? I posted this question once before here:
http://www .eng-tips. com/viewth read.cfm?q id=273479& amp;page=1
it has more pictures.. thanks in advance
[IMG]http://i
http://www
RE: Sweep cut along 3d sketch (complex path)
Dan
www.eltronresearch.com
Dan's Blog
[IMG]http:
[IMG]http://i
the box by the first red arrow lets me select the first segment and sweep along it but not the rest...
the box by the second red arrow i tried selecting all the segments but its not letting me either...
Rob Stupplebeen
Rob Stupplebeen
Rob Stupplebeen
http://
that is ok if i just want to extrude a circle shape but i wanted to do a rectangle with one end radius-ed and have it twist to stay perpendicular to the surface it was cutting... I have no clue how to make that one happen. There are some options on the sweep cut for twisting but none of them worked for me.. but this works for now. Thanks guys.
http://w
anyone have a tutorial on this feature?
Ed Eaton Sometimes surfacing can be a big help.
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
"Node news is good news."
