200hp motor burns contactor
200 hp 3 phase 2speed motor burning up high speed size 5 contactor. Low speed draws 64 amps/high speed amps 223 when running correctly. Motor has been rebuilt. Time delay between low speed and high speed. aprox 30 sec. shows aprox 3-4% voltage drop at MCC contactor can, motor is another 85 ft away. Cutler-hammer contactor vibrates when pulled in. (more than normal) Burns (a phase) when going to high speed, contact point melted. Replaced contactor three times, with new size 5 cutler-hammer style.
Same problem occurs about every 5 to 6 weeks. Where else should I be looking?
RE: 200hp motor burns contactor
Perhaps the control voltage dipping from something. As frequent as it is occurring you should immediately get a recorder going on the control voltage across the contactor coil. You will likely see something immediately if not sooner.
Keith Cress
If the contactor is at the MCC and not near the motor, you can rule-out voltage dip, IMO.
Bill
"Why not the best?"
Jimmy Carter
