Blowdown with liquids
For gas plant blowdown calculation, if the vessel has liquid in it, how would the calculation be done?
RE: Blowdown with liquids
liquids have higher densities than gases which means higher forces in velocity changes (by momentum conservation)
liquids can vaporize, the cool down process can produce temperatures which are below the limits admitted for the plant's materials
