Black or white??
Black or white??
Whats the "pro's" and "con's" with "white" and "black" color, on an hydraulic reservoir??
Does black color radiate more heat than white?
System is operated in high ambient temperature under direct sunlight. The hydraulic system itself, is also generating excessive heat. Goal is to keep reservoir temperature as low as possible.
![[hourglass] hourglass](https://www.tipmaster.com/images/hourglass.gif)
Thank you in advance for any explanation and/or advice!!
Per A, Eng in Construction(-73) and Forestry (-81)
RE: Black or white??
TTFN
TTFN
