Exhaust debate
Exhaust debate
am having a friendly debate.
if you have a 3" y pipe tied into a
3.5" peice of straight exhaust pipe...no muffler..6' long..
would it have any advantage over a 3" y pipe tied into a
3" pipe of same configuration.
ie...would not the restriction at the 3" collector cancel any advantage of the 3.5" pipe.
ie...my "opponent" states it will require more HP with the 3" pipe.
thanks.
thanks.
RE: Exhaust debate
RE: Exhaust debate
A case of bigger is NOT better! It made it under the 105db limit, too. Louder is not faster!
Rod
RE: Exhaust debate
Isn't it amazing what sells? More of anything isn't always better in reality but the concept sure sells!
I have one question about exhaust that I've yet to see discussed. If say 1000 cfm of exhaust gas leaves an engine at 1100°F, by the time it reaches the end of the tailpipe, its temperature will have dropped to about 300°F and there will be a corresponding significant loss in volume as well as a slight increase in its viscosity. So, if you have a 3" diameter pipe at the exhaust manifold, why do you need the 3" pipe all the way to the tail pipe? Seems like those coffee can size stainless exhausts the kids love today are more decorative than anything else.
Chumley
RE: Exhaust debate
What you described could be due to not only the diam but also the length of the pipes so that the exhaust pulses and their timing and inertia may have helped scavenge more gas as it exited from the cylinders leaving more room for the incoming fuel and air.
RE: Exhaust debate
Of course. That was the purpose in building a "tuned" exhaust system. Believe me, we tried a multitude of different systems but ended with the one I described. I don't recall the length, it HAS been a long time, but it exited the rear. The problem is not knowing how to configure an exhaust system for a particular application, it's choosing the right formulae to find the correct dimensions. There are great works available that give, in detail, how to find all this stuff. THEY DO NOT ALL AGREE!
Trial and error works great IF you have lots of time and money. Choose any book. Do the math. Build the system. (So far so good, huh?) Now, how do you know you have the ultimate unless you try a few more systems? Shucks! Now we are back to 'trial and error'. The solution is to engineer the very best system you are capable of and TEST, TEST, TEST!!! What I have found is that the best engineered system is often NOT the best performing system.
Chumley, dammit, when are you going to give it up and join us? We need more people in here that I agree with.
Rod
RE: Exhaust debate
I had assumed that if you have a 3" collector...then rather you have a 3" dia straight piece of pipe or no pipe at all after the collector that there would be no difference in hp/torque output.
ie...friction loss is not a factor here..and since there are no bends in the pipe then static pressure loss is out.
i just don't see where pipe after the restriction is a factor.
RE: Exhaust debate
Could be! Perhaps a trip to the bookstore and a few weeks of study could bring you up to speed?
Rod
RE: Exhaust debate
for instance a 3" pipe with a constant radius 90deg bend.
the 90 deg bend has approximately the same restriction as 9 feet of straight pipe.
I don't know weather it affects the wave dynamics timing in the same way, I would assume not.
RE: Exhaust debate
As has been said above there are many different factors that have effects and interactions. Things such as the surface roughness of the pipe itself, speed of the test engine, valve timing etc etc
I think that Ricardo invented their WAVE suite of software was an attempt of trying to quantify things like this.
MS
RE: Exhaust debate
Chumley is right, the drop in temperature down the pipe has a big effect on the dynamics, including the wave speed. Getting your temperature profile right to the n'th degree doesn't seem to be that important, but then it could be part of the reason for my first paragraph!
Carnage - I don't think bends would provide much of an impedance mismatch to bounce waves off - I can't remember what the critical angle is for a diffuser, but I think if you run a 20 degree taper then the gas can't 'see' the join. I think a bend would be like that. To get reflection you have to create the equivalent of a hydraulic jump if you know what that is, ie an abrupt acceleration or deceleration.
Cheers
Greg Locock
RE: Exhaust debate
Cheers
Greg Locock
RE: Exhaust debate
If your engine is making 100 HP, there'll be absolutely no difference between a 2" pipe, or a 3" pipe, or a 4" pipe downstream of the collector: the frictional losses at that flow velocity will be negligible.
My guess is your engine would have to making upwards of 1000 hp for you to see a measurable difference between 6' of 3" pipe and 6' of 3.5" pipe.
I do know that I developed a system for the ZR-1 Corvette that reduced the system backpressure while reducing system pipe diameter from 2-3/4" to 2-1/4".
Because most of the losses in this system are at the entrances to and exits from the mufflers and resonator.
And of course the smaller diameter system weighed significantly less, while having better subjective sound quality.
RE: Exhaust debate
you decreased the size of the exhaust pipe by reducing the other restrictions and reduced backpressure at the motor.
SO Unless someone shows me otherwise...
If I have a 3" "restriction" at the manifold or at the Y of the exhaust pipe of a V8 engine making 270 hp...
then increasing the 3" pipe downstream of the restriction to 3.5" will aid no benefit other than by reducing the restrictions at the muffler and any bends.
or more simply..
If the pipe downstream of the 3" restriction was just a straight run out say 10' long, no muffler...then going with 3.5" diameter pipe downstream of the 3" restriction gains me nothing..
Right???
Because "someone" is trying to tell me there is some sort of gas pulse loss or something like that.
I contend there is an irrelevant amount of friction loss of any type involved in my example.
RE: Exhaust debate
Just because your headers have a 3 inch collector is NO guarantee that a 3 inch tailpipe is needed. The length of the headers, their configuration, length of collector, duel/single pipe, 'X' pipe, 'H' pipe, type of silencer , number of resonators, cats, -------on and on. The only factory car I ever owned with a 3 inch exhaust system OEM was my 64 Ford Fairlane Hy-Po 271hp 289cu.in. and it was only a SINGLE pipe system. Seemed to work ok , though.
Bottom line is that you may find performance increase with SMALER dia system that a full 3 inch. Maybe not, but a VERY good bet you will.
Rod
RE: Exhaust debate
Hmmm.
Did a dyno test on a 318 Dodge engine about 8 years ago and used the stock exhaust, complete with no alterations. Got 185 bhp. Took off the manifolds and installed headers 2.5" down pipes to 2.5 inlet 2.5 outlet cats, then to 2.5 inlet 2.25 outlet mufflers,(two of em) and gained 25 bhp.
We used a pressure transducer in the EGR port to measure backpressure. Had 4 psi at 4000 with the stock system, 1.5 psi with the headers, and we gained 35 bhp too. At no time did we ever obtain positive scavaging.
General logic tells me that if you have to increase backpressure to make it run right, you have a problem with camshaft profiles, ignition timing rate, fuel induction (my best guess) or engine mechanicals. Otherwise, we would see Top Fuel 7000 bhp engines with butterflys in the exhaust headers!
Franz
RE: Exhaust debate
Back pressure is bad and if you can get the exhaust to exit in a low pressure area on the vehicle all the better.
For no or very little power loss the exhaust must flow 2.2 cfm per horsepower (0.2 psi back pressure, 5 to 6 inches of water)
To achieve open pipe power with a silenced system you require an expansion chamber at the end of the collector. This expansion chamber must have a volume of 8 to 15 times the size of one cylinder and have an abrupt change in cross section. This then feeds into the rest of the system and silencer/s and as long as it flows 2.2cfm per hp no power loss will result.
The expansion chamber basically replicates an open pipe.
The article also discusses manifold design but is not easily summarised here.
There is a picture of my expansion chamber here www.BeardmoreBros.co.uk\website pages\new_project_engine_page5.htm
John
RE: Exhaust debate
they are jpegs so the load is a bit slow but the link works as of today.
innovator, is this the article you are refering to?
RE: Exhaust debate
Rod
RE: Exhaust debate
Buzz jets (e.g. the German V1 during WWII) use this principle.
RE: Exhaust debate
Anyhow..I have installed headers and 2.5" true duals.(gsmotorsports.com).lessening backpressure, increasing torque/hp.(even at low rpm)..maybe the x-pipe synched the pulses feels like a nice gain..have'nt dyno'd yet.
RE: Exhaust debate
In general, the higher the specific output(and therefore the greater the valve overlap) the greater will be the power loss per unit increase in backpressure.
More backpressure produces more charge dilution and/or reduced scavenging during the valve overlap period.
For this same reason, 4-valve engines are generally much less sensitive to exhaust backpressure.
Ford produced an excellent but not widely-disseminated internal-only paper on this topic during the MN-12 program.
