Automate pdf's with pro-batch
I'm currently trying to get prints to batch automate to pdf output. I was using a psting I found online that uses Ghostscript. I've gotten to the point where I have Pro-E setup with a new "pdf_win" printer option that prints post scripts files to a folder in various size prints. This folder is then converted to PDF files. Now when I move on to the pro-batch step I don't get an option to select the "PDF_win" printer that was setup in Pro-E. Also I am running wildfire 2.0. Any help in getting past this step would be greatly appreciated. Does the new printer need to be setup in Probatch? If so how??
RE: Automate pdf's with pro-batch
Do you have the config.pro option "pro_plot_config_dir" set to the location of the pdf_win.pcf file?
Fighter Pilot
Manufacturing Engineer
