Load on lower shock mount
Hi there,
Quick question, hoping to find some advice...
I am trying to perform an FEA on an end eye I want to use on my rear shocks, (lower mount)
How do I determine the load to apply? I have the vehicle weight and damper curves.
Here's what I was thinking: Use the weight at the given corner, and the force applied at 4in/sec (simulate load seen while going over a bump)
Then apply a factor of safety, is it really that simple?
Thanks guys
Thanks guys
RE: Load on lower shock mount
Look at the shock mounting hardware and see what kind of loads it can possibly transmit.
As long as your mount can accept as bit a load as the shock can transmit through its hardware, you should have some factor of safety.
(actually, I just welded up some shock brackets for my bastard project car. So far, nothing has bent or fallen off.)
Jay Maechtlen
http://www.laserpubs.com/techcomm
It does depend whether you are circuit racing or on roads or Baja, and whether you are kerb hopping when circuit racing.
Cheers
Greg Locock
Tim
Cheers
Greg Locock
I would think the lower mount would be fatigue limimted as well, why is this not the case?
Cheers
Greg Locock
As Greg mentioned, this is a rare "overload" type event and hence is usually specified as a one time load rather than a fatigue validation. Load range 20-30kN is typical.
Tim
Doesn't damping have to be proportional to spring rate?
Spring rate for given type of ride (luxury vs sport) would be proportional to vehicle weight?
Jay Maechtlen
The damper can only transmit so much force and this is directly related to the damping curves, so you are much better off looking at those to find your worst case load.
Tim
Yes, damping forces may be adjusted for the vehicle mass / spring rate, but as I noted above, damping is not the load you need to worry about.
In fact, the added damping that might accompany a spring rate increase actually helps the worst case shock loading as it will reduce the velocity of the suspension at the end of travel ( Vs no damper change). A secondary effect in changing the spring rate will be that it will also change the spring load at full extension - assuming no other changes the stiffer spring will have less force.
