Water Curtain
Water Curtain
Water Curtain
I'm looking for information or resources to calculate the amount heat reduction provided by a water curtain given a known flow rate.
Lees' Loss Prevention book provides some references but I'm unable to locate them on the Web.
Dan Marr
"Real world Knowledge isn't dropped from a parachute in the sky but rather acquired in tiny increments from a variety of sources including panic and curiosity."
RE: Water Curtain
If you have access to NFPA 15, Annex A gives you some latent heat of vaporization for H20 and you can reverse calculate it based on your application rate on the object you are protecting.
RE: Water Curtain
Stookeyfpe,
Thanks for pointing me in the right direction.  I'll look through it.
Fireguy519345.
Thanks for the link.  I have all of the standards, dating back to 72 in PDF, so i'll have a look through them.
Dan Marr
