Excel VBA code to generate loadcases
Hi there,
Via Excel it should be possible to write VBA code to generate loadcases automatically.  However, it is difficult to find out with the FEMAP help file how to do this.  I tried some code but unfortunately I did something wrong.  It generates the load definition cases but doesn't include the actual loads.  Can somebody see what I do wrong?
The code looks like this:
Dim App As Object
    Set App = GetObject(, "femap.model")
    Dim ls As Object
    Set ls = App.feLoadSet
    Dim fs As Object
    Set fs = App.feLoadMesh
    Dim ld As Object
    Set ld = App.feLoadDefinition
    Dim ID As Integer
    Dim rc As Integer
    Dim Name As String
    Dim File As String
    Worksheets("Input").Activate
    Range("F3").Select
    ID = 1
        Name = ActiveCell.Offset(ID, -5)
        rc = ls.Get(ID)
        ls.Title = Name & ID
        ls.setID = 1
        ls.Active = ID
        ls.NLOn = 1
        ls.NLIncrements = 10
        ls.NLMaxIterPerStep = 25
        ls.NLStiffnessMethod = 1
        ls.NLStiffnessIter = 5
        rc = ls.Put(ID)
        rc = ld.Get(ID)
        ld.Title = "Pin Loading" & ID
        'ld.DataType=7
        ld.loadTYPE = FLT_NFORCE
        ld.setID = ID
        rc = ld.Put(ID)
        rc = fs.Get(1)
        fs.setID = ID
        fs.LoadDefinitionID = ID
        fs.meshID = 1274
        fs.CSys = 0
        fs.Type = 1
        fs.dof(0) = 1
        fs.dof(1) = 1
        fs.Load(0) = 200
        fs.Load(1) = 10
        rc = fs.Put(1)
        rc = fs.Get(2)
        fs.setID = ID
        fs.meshID = 2635
        fs.CSys = 0
        fs.Type = 1
        fs.dof(0) = 1
        fs.dof(1) = 1
        fs.Load(0) = 200
        fs.Load(1) = 20
        rc = fs.Put(2)
End Sub
Something goes wrong in the "loadmesh" property. Anyone who likes to puzzle?
Grtz,
Kees
RE: Excel VBA code to generate loadcases
Hey!
I also have the same issue. My code is almost the same.
If you remove the line fs.LoadDefinitionID = ID, you will se the loads in the section "Other Loads/on mesh".
But I do not manage to put the nodal force into the load definition.
Can someone help us?
Thanks!!
Ben
surely the help desk can help ?
Hi jokerbenj,
Finally I figured out the problem myself.
See the enclosed procedure code below which works!  I figured this out some time ago (can't remember what was missing at that time), but comparing the codes, I think it had to do with the "active" set.
This code works OK!  Try it. The "activeoffset" command refer to a table made in excel.  I hope you can read it.
Sub Create_Loads()
'Attach to the model in a FEMAP session that is already running.
Dim femap As Object
Set femap = GetObject(, "femap.model")
Dim LS As Object
Set LS = femap.feLoadSet
Dim LM As Object
Set LM = femap.feLoadMesh
Dim LD As Object
Set LD = femap.feLoadDefinition
Dim Col As Integer
Dim Count_RC As Integer
Dim ID As Long
Dim RC As Long
Dim Row As Long
Dim S_ID As Long
Row = 2
ID = 1
Count_RC = 0
While Worksheets(1).Cells(Row, 1).Value <> 0
    'ID = Worksheets(1).Cells(Row, 1).Value
    S_ID = Worksheets(1).Cells(Row, 1).Value
    RC = LS.Get(S_ID)
        LS.Title = Worksheets(1).Cells(Row, 2)
        LS.Active = S_ID
        LS.SetID = 1
    RC = LS.Put(S_ID)
    While Worksheets(1).Cells(Row, 3).Value > 0
        'ID = 1
        'Apply node loads
        If Worksheets(1).Cells(Row, 6).Value <> 0 Or _
            Worksheets(1).Cells(Row, 7).Value <> 0 Or _
            Worksheets(1).Cells(Row, 8).Value <> 0 Then
            RC = LD.Get(ID)
                LD.Title = Worksheets(1).Cells(Row, 4) & " Force"
                LD.loadTYPE = 1 '(FLT_NFORCE)
                LD.DataType = 13
                LD.SetID = S_ID
            RC = LD.Put(ID)
            If RC <> -1 Then Count_RC = Count_RC + 1
            RC = LM.Get(ID)
                LM.meshID = Worksheets(1).Cells(Row, 5) + 10
                LM.dof(0) = 1
                LM.dof(1) = 1
                LM.dof(2) = 1
                LM.Load(0) = Worksheets(1).Cells(Row, 6)
                LM.Load(1) = Worksheets(1).Cells(Row, 7)
                LM.Load(2) = Worksheets(1).Cells(Row, 8)
                LM.Type = 1 '(nForce)
                LM.LoadDefinitionID = ID
                LM.SetID = S_ID
                'LM.layer = 1
                'LM.Color = 1
                'LM.SetID = 1
            RC = LM.Put(ID)
        End If
        'Apply node moments
        If Worksheets(1).Cells(Row, 9).Value <> 0 Or _
            Worksheets(1).Cells(Row, 10).Value <> 0 Or _
            Worksheets(1).Cells(Row, 11).Value <> 0 Then
            ID = ID + 1
            RC = LD.Get(ID)
                LD.Title = Worksheets(1).Cells(Row, 4) & " Moment"
                LD.loadTYPE = 2 '(FLT_NMOMENT)
                LD.DataType = 13
                LD.SetID = S_ID
            RC = LD.Put(ID)
            RC = LM.Get(ID)
                LM.dof(0) = 1
                LM.dof(1) = 1
                LM.dof(2) = 1
                LM.Load(0) = Worksheets(1).Cells(Row, 9)
                LM.Load(1) = Worksheets(1).Cells(Row, 10)
                LM.Load(2) = Worksheets(1).Cells(Row, 111)
                LM.Type = 2 '(nMoment)
                LM.SetID = S_ID
                'LM.layer = 1
                'LM.Color = 1
                'LM.SetID = 1
            RC = LM.Put(ID)
        End If
        ID = ID + 1
        Row = Row + 1
    Wend
    Row = Row + 1
Wend
'Combine the loadcases
Worksheets("Overview").Activate
For Col = 3 To 23
    S_ID = Cells(1, Col).Value
    RC = LS.Get(S_ID)
        LS.Title = Cells(2, Col)
        LS.Active = S_ID
        LS.SetID = 1
    RC = LS.Put(S_ID)
    For Row = 7 To 30
        If Cells(Row, Col) = "x" Then
            RC = femap.feLoadCombine(Cells(Row, 1), S_ID, 1)
        End If
    Next Row
Next Col
MsgBox ("Amount of error codes is " & Count_RC)
End Sub
