Stirrer Design Query
Want to design a stirrer with a propeller to achieve best mixing and create max downward thrust to push mixture towards a discharge port @ the base of the vessel.
 Any recommendations on optimum shape incl. contact angles of fins with shaft?
RE: Stirrer Design Query
I'd suggest you mess around with the information you'll find at Chemineer.
http://www.chemineer.com/app_guidelines.php
Lots of different prop designs, it depends on what you're mixing, and what you're trying to accomplish.
Mixture of polymer & water in autoclave (same densities). Ultimate aim is to push the mixture down & out from a discharge valve @ the bottom. Need a propeller design which would facilitate the same.
