DGA values of transformer oil
hi can some one talk on which is the best and easy to use DGA  oil analisys instrument ? many companies reclaim to be the one but is best get information from the real world
regards
amper
RE: DGA values of transformer oil
IMO the way to go is to draw the DGA sample and send it to a lab.
well what happened is some comments mentioned that extract a sample send to lab get delay for couple a day is just waste you time because analysis will be fake . that the reason which are looking to see options
I agree with Zogzog.  Make sure the sample is taken properly, sealed and then sent to the lab.  I sincerely doubt any lab would fake the analysis.  The few days lag between the sample and the received analysis shouldn't be a problem.
If it is broken, fix it.  If it isn't broken, I'll soon fix that.
