CLORIDES CORROSION
CLORIDES CORROSION
I have a reinjnection water with 67000 ppm of clorides.
Wich is the pratically solution for the piping in this case.
Carbon steel or Duplex material?
Wich is the mechanism of corrosion of clorides on carbon steel? If there is an absence of oxigen is the corrosion inhibited? Thank's for your answer.
P.S. Naturally the duplex is the bettere choice, but is carbon steel technically applicable?
For the moment we not consider GRP/GRE pressure is too elevate
RE: CLORIDES CORROSION
My experience with this is lab based and I would say stainless but there may be a cheaper solution.
Thomas J. Walz
Carbide Processors, Inc.
www.carbideprocessors.com
Good engineering starts with a Grainger Catalog.
Steve Jones
http://www.oilandgaspeople.com/cv/11499664
http://www.linkedin.com/pub/8/83b/b04
