H-Pile set in drilled shaft (not driven)
I'm looking for some guidance or information on the design and installation of steel H-piles set (not driven, but placed) in a drilled shaft that is then filled with concrete.
Any literature or specifications out there? Any experiences?
Thanks!
Thanks!
RE: H-Pile set in drilled shaft (not driven)
Of course accuracy of setting is the crucial point and this will be helped if there is a bored pile casing at the upper level.
But some more info would help. Is this a basement construction? Is there a length of "empty bore" after completion of the bored pile and H-Section?
www.PeirceEngineering.com
Also, this type was used in Rhode Island for soldier piles with pre-cast concrete lagging along the Amtrak corridor. My understanding is that the drilled shafts were augered with a special rig that injects the concrete on the way up; then the H-pile is pushed into place while the concrete is fresh.
