Non-return valve type applicable for use with Reciprocation Compressor
In the past it has been my experience that piston non-slam type non-return (check)valves were the technology to use on the discharge piping to prevent flow reversal to a reiciprocating gas compressor.
More than one Tender on a gas compression project have submitted an axial flow type non-return valve.
What experience and would anyone have comments regarding this non-return valve application variation?
Please provide any links or reasons for your comments such as a case history.
DANIEL C. SMAISTRLA
Equipment: Centrifugal Pumps and compressors; Steam and Gas Turbines; Reciprocation Engines and
Compressors
Specialties: Machinery diagnostics, design application of compressors, FEED,Detail Design,construction,commissioning and maintenance.
DANIEL C. SMAISTRLA
Compressors
RE: Non-return valve type applicable for use with Reciprocation Compressor
David
Check:
ht
Rdg. Wolfgang
