Default Output Filename from Post Process
Does anyone know how to change the default name for the output file when posting? It currently defaults to the part file name and I would like it to default to the program group name if possible.
Thanks in Advance
Cheers
  Steve Griffiths smile
If you want to make apple pie from scratch, first you must create the universe!
RE: Default Output Filename from Post Process
You can do this in the post - there are probably custom commands around.
Something you might look at: If you have LIBRARY_CAM_OUTPUT in your configuration, then the system will create a folder for each setup you create, a folder for each post you use, and name the ouptut file with whatever program or operation you selected. You can change your configuration to cam_library.day of you want to see how it works.
Mark Rief
Product Manager
Siemens PLM
