Nx7 Performance on windows 7 64 bit
I have a new I7 box with 8 gig of ram and Nividia quadro 1800, running windows 7 64 and ugnx 7 (64). I find it extremely slow even running routine operations. I have benchmarked it against nx7 running on windows 7 32 bit and indeed there is a performance issue. Even the same operations run on nx4 xp are 2 to 3 times quicker.
Any ideas or thoughts?
RE: Nx7 Performance on windows 7 64 bit
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
That could get a dept manager into some trouble.
I'de like to make the move but have been reluctant.
Anyone else out there able to speak to this?
TIA
Dave
Running on a Intel Core 2 Duo E8500 3.16 GHz with 4 GB Ram.
Cheers
Steve Griffiths
If you want to make apple pie from scratch, first you must create the universe!
Are the systems on the same network? Preformance is highly depending on the distance between client and server (when using TC of course).
Or have you placed the license server on the same workstation as where you NX installation is on?
Is your HardDisk almost full?
Best regards,
Michäël.
NX4.0.4.2 MP10 / TCE 9.1.3.8_build_0711 / NX6.0.2.8 / NX7.0.0.9
Belgium
On my machine with XP 64 is NX 7.5 with some operations hugely slower than NX 7 (both are installed). E.g. file opening lasts up to 10-times slower!!! Any ideas? Its becoming disturbingly annoying to work with. I´m thinking to stay with 7 until this is fixed :((
br, B
The first time a file is opened in a new version, NX has to update its internal structure to the new format. Multiply this effect by the size of your assembly and you can see where long slowdowns can occur. If the file(s) are saved in 7.5 and opening performance is still slow, then it is time to worry.
