hinge movement as a sub-assembly
Probably a dumb question, but have to ask.
Within the bicycle frame assembly, there's a hinge (sub-assembly) to fold or unfold the frame. In the main assembly, I can't open the hinge  (or move it within the "hinge" mating limits) and fold the frame. However, if the hinge ass. file is open and I modify the position of the hinge, the hinge opens to the same position (angle) in the larger assembly. I suppose this is just the way things work?
Correct me if I'm wrong, but, to be able to move the hinge in the main assembly, I would have to assemble the hinge components within the same assembly, and not insert it as an already created assembly into the new, larger assembly?
RE: hinge movement as a sub-assembly
Look in Help for "Flexible" and that should get you on the right path.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
Right click on Hinge sub assy. while in the main bicylcle assy. & go to Component properties.
Select flexible in right bottom corner.
You need to resolve the assy. before doing it.
Hope that helps.
Gurjeet Singh
Much better than I was hoping for. In both replies got the answer that makes the hinge open/close. For being detailed and right on spot, a star for Gurjeet.
