Bolted Joint Connections
Does an inspector of bolted joint connections, in a structural steel building,require a certification from aisc, rcsc or some other authority? ...and if so, what is that governing authority?
RE: Bolted Joint Connections
Garth Dreger PE
AZ Phoenix area
http://www.FerrellEngineering.com
woodman88 - many states have amendments to the IBC which specify the qualifications of inspectors.
Garth Dreger PE
AZ Phoenix area
