Eccentric in plane load on L shape weld
Hi Guys,
I need to check capacity of a "L" shape weld with an application of in plane eccentric load (Assuming an outrigger angle welded (L-Shape) to column with a vert load at end).
Can some help with a manual calculation for this case. I have tables from code, but no hand calcs to support that.
Thanks in advance.
Thanks in advance.
RE: Eccentric in plane load on L shape weld
Have a look at this site:-
ht
desertfox
It's the same as desertfox link shows as per this image.
Just use the formula at the site I gave you.
desertfox
