Interaction of Duct Fittings
Hi! Could somebody help me regarding this?
All of the data on loss coefficients are based on fully developed flow of air into the fittings ( free stream loss coefficient ). Air leaving fan, elbow, tee or any duct fittings is always turbulent and distorted. You actually need a certain length ( 5 to 10 dia in duct lenght ) for the flow to fully develop. If the air flow does not become fully developed the pressure drop of the downstream fittings will generally increased including noise.
I am actually looking for methodology / reference or books that tells you how to calculate or compensate for fittings installed very close to each other. Using the loss coefficent for fully develop flow is inaccurate.
I have tried ASHRAE and It does not tell you about this problem.
Thank you
