Vacuum Contactors
Vacuum Contactors
When we are using a circuit breaker to protect a capacitor, we typically consider a special circuit breaker able to interrupt the capacitive currents.
If we are using a vacuum contactor (or SF6 contactor), is it also important or any specific characteristic should be considered?
or only the fuse has to be for capacitors?
I thank you in advance!!!
RE: Vacuum Contactors
If it is broken, fix it. If it isn't broken, I'll soon fix that.
I thank your answers!
One additional point:
Is there any standard in which I may "support" this?
Because, typically suppliers try to defend their positions and of course, standards are always usefull to clarify things.
Best Regards,
