PRV vs. Vapor space Riser for Liquid full 2" hexane piping?
Our plant utilizes hexane in our processes. We had an incident with a liquid full 2" line overpressuring due to thermal expansion of the hexane in the blocked in system. The result was gasket failure at the flange.
Now I am evaluting a new 2" piping layout that could have liquid full conditions, full sun exposure, blocked in by valving. One solution is a PRV. Can we use a stand pipe or riser say 4-6 feet tall with a fixed cap or valve with blind on top ( similar to a high point bleed) as a safety vapor space so as to avoid a true liquid full condition and potential failure.
I am finding little techinal data on such a "riser" vs. PRV. It is not always suitable to use PRV since we do not have a flare line to dump to in every case. Any suggestions on how to approach. Calculations for the riser pipe for vapor space seem difficult to find.
RE: PRV vs. Vapor space Riser for Liquid full 2" hexane piping?
Arn't the real solutions a relief valve in the proper locations, adding a vent or drain system, perhaps combined with a higher pressure rating for the system and ensuring that your joints make up properly.
"We have a leadership style that is too directive and doesn't listen sufficiently well. The top of the organisation doesn't listen sufficiently to what the bottom is saying." Tony Hayward CEO BP
http://www.youtube.com/watch?v=hpiIWMWWVco
"Being GREEN isn't easy." Kermit
http://virtualpipeline.spaces.liv
