Annotation Update
Annotation Update
Hi All,
Here is my sequence of events:
I am running SW 2009 SP 2.1 on a windows XP machine (also behaves the same on 64 bit vista)
1. Create model
2. Create Drawing from model using custom template, may or may not insert additional views.
3. Dimension and detail drawing using a mix of dimensions imported from the model and reference dimensions added in the drawing.
4. Save.
5. Close drawing or add new sheet and create second drawing.
6. Re-open Drawing or return to first sheet.
- Now here is where it starts getting aggravating-
Open with quick view is fine - as soon as the sheet tries to load fully the "Annotations Update" opens in my property window with "right click on annotations to toggle visibility. "New annotations will be hidden until selected." is shown in a message window and a "Show previously hidden annotations" check box is given in an options window. The problem is then that:
1. Some dimensions/annotations are automatically deleted.
2. Some annotations are moved to other views.
3. Some dimensions are switched to hidden
4. Some dimensions are moved to other views AND switched to hidden.
I then get to accept or cancel the annotations update – regardless of what I choose the changes are applied and my drawing is ruined and I have to start from scratch.
The real frustrating part is that this only happens when I open a drawing *Sometimes*. Is there a setting that I can use to turn this off, undo or negate this effect? I just want to return to a sheet and have it stay the same as it was when I saved it! Any help would be greatly appreciated. I need to fix this ASAP.
-Keith
1. Create model
4. Save.
-Keith
RE: Annotation Update
What graphics card and driver are you using?
I can say that the problem is definitely intermittent, it seems to happen on the drawing that's the most important at the time, and if my memory serves me correctly, once I let my drawing get raped by the annotations update 1 time, it doesn't seem to want to do it again.
