Nitrogen gas density calculation
I have a tank with internal volume 2.01 L filled with N2 gas at 308K. The pressure inside the tank is 340.23 atm. I am trying to find the density of gas inside the tank. This is required becase the tool inside this chamber cannot operate above densities of .036 lb/in^3.
P = 340.23 atm ; T = 308K ; V = 2.01 L ; R = .0821 L.atm/Mol.K
This is how far I got,
1) Using Ideal gas equation,
PV = nRT
n = 27.04 moles
Thus, density = 376.67 g/L = .013 lb/in^3
2) Using Van Der Waals correction,
P = (nRT/(V-nb)) - ((n^2)*a/V^2)
For Nitrogen (N2), a = 1.37 L^2-atm/mol^2 ; b = .0387 L/mol
n = 49.97
Thus, density = 696 g/L = .025 lb/in^3
Now when I toook the pressure down to 204.13 atm, I expected the density to go down but the density infact increased which did not make any sense to me.
When, P = 204.13 atm ==> Density = .026 lb/in^3 From van Der Waals Equation.
On the other hand, when P = 204.13 atm ===> Density = .008 lb/in^3 using Ideal Gas Equation.
Can anyone explain how the density is going up using Van Der Waals equation when the pressure is reduced?
Mike
PV = nRT
n = 27.04 moles
n = 49.97
Mike
RE: Nitrogen gas density calculation
You might try other EOS methods; BWR maybe.
"We have a leadership style that is too directive and doesn't listen sufficiently well. The top of the organisation doesn't listen sufficiently to what the bottom is saying." Tony Hayward CEO BP
http://www.youtube.com/watch?v=hpiIWMWWVco
"Being GREEN isn't easy." Kermit
http://virtualpipeline.spaces.liv
Using your figures for a, b, R, T, and P, I get n ~ 23.02 not 49.97.
Bringing the pressure down to 204.13 atm, I get n ~ 16.
Therefore kindly check your calculations and report back. Thanks.
Uconeer is a free units conversion program available from the link in my signature below.
Katmar Software
Engineering & Risk Analysis Software
http://katmarsoftware.com
25362 & katmar you are both right. Apparently it was a simple algebric error in my calculations. n is approximately 23 using Van Der Waals correction to ideal.
Mike
