303 Vs 304L
303 Vs 304L
in our application, 304L component is press-fitted to 303 component (as insert and sleeve). Recently, our supplier unintentially used 303 for both components, huge amount of products have been made, business wants to assess the impact before scrap.
my concern would be steel galling? but can't tell whether it will be worse or the same with supplier's mistake.
any guidence??
notes:
Corrosion is not issue here
304L component requires Rmax 8 surface finish (any impact on surface finish?)
Our supplier has performed testing and dimensional check and all positive, but should I trust them?
any guidence??
notes:
RE: 303 Vs 304L
RE: 303 Vs 304L
