Shear Strength Correlation
I'm trying to find a published correlation I can reference between percent compaction (ASTM 698) and effective stress shear strength (c', phi') for a compacted decomposed granite that classifies as SM (non plastic, >95% relative compaction, about 25% fines, minor gravel, total unit weight about 135 pcf).
RE: Shear Strength Correlation
DM-7 has a plot that shows friction angle, RD, and material type to get phi'. Assuming 95% RC ~ 75% RD, it gives 35 for phi', but that sounds a bit conservative to me for the material you are talking about, which I expect is angular and broadly graded. I'd start with 37 and some token cohesion (maybe 200 psf).
(Thinking about the WV issue - Gail Atkinson may have published something about attenuation in the east, but I'm at a loss for site-specific w/o identified sources.)
DRG
Cheers
Granular material: RC% vs phi'
see Wong and Duncan (1974), Hyperbolic Stress-strain Parameters for Nonlinear Finite Element Analysis of Stresses ans Movements in soil Masses.
Compacted Cohesive Soils: RC% vs c',phi'
see US Department of Interior (1973), Design of Small Dams
Other references:Dr vs phi'
see Meyerhof (1956), Penetration Tests and Bearing Capacity of Piles
Meyerhof (1976), Bearing Capacity and Settlement of Pile Foundations
