Clone Assembly
Clone Assembly
Hi All,
I would like to clone full assembly with same part names in another directory.When I go for cloning it always asks for prefix, suffix ,replace or rename.
Is anyone knows to clone same assembly with same part names.
Please suggest?
Please suggest?
RE: Clone Assembly
When you are in the top-level assembly, just do: File > save as > New name in new directory
and you should be fine . . . unless I am missing something.
Don't forget to put what version of NX your are using.
RE: Clone Assembly
That will put the assembly file in the new directory but will not take the components with it. I think the OP is asking how to copy the entire assembly (assembly file and all component files) to a new folder.
RE: Clone Assembly
RE: Clone Assembly
Now it works by using space as suffix.
RE: Clone Assembly
UG Zip is the tool you want. I use it all the time to ditch orpaned parts and junk files from the project folder.
No better way but Seimens probably should have deployed a native tool for this a long time ago.
