R19 Associated geometry/connection management not working...
Recently went from R18 to R19.
Having trouble with the Associated geometry/connection management feature in R19.
I have MBD that is R19 only that I need to extract info from. At first I thought it might be the model, that there was no linked association between the dimensions and the model features.
BUT I opened up a different model created in R18, which when opened in R18, gives me the associated geometry. I open up the very same CatPart in R19 and it still does not bring up the connection management window and give associations.
Is there some change in this revision? Or a setting to change?
