Reference Dimensions in Assemblies
I have created a reference dimension (RD2@Annotations) in an assembly  using Smart Dimension in the Sketch tab.  After I rebuild, the dimension disappears.  I have tried the following settings:
Right click Annotations folder and check the following:
-Display Annotations
-Show Feature Dimensions
-Show Reference Dimensions
-Show DimExpert Annotations
-Enable Annotation View Visibility
Document Properties/Detailing, check Display all types, and display assembly annotations.
I created a new assembly with two dummy parts and can see the reference dimension with no problem, so it does not seem to be a system setting.
So - What can I do to see the reference dimensions in the first assembly?  And is there any way to access a list of reference dimensions?
RE: Reference Dimensions in Assemblies
Make sure under View tab, Annotations are set to show.
Deepak Gupta
SW2009 SP4.1
SW2007 SP5.0
MathCAD 14.0
That fixed it, thanks!
